Hey guys I’m currently trying to replace my antenna to the retractable one has anyone done this before, if say I could really use the help thanks
Discussion Starter #4
Discussion Starter #6
If your hooking up a power antennae you splice into the power accessory wire on your harness. The same one that powers the antennae to go up when the radio is on.
I removed my stick one and got a delete kit. Installed a hidden power one under my dash.
okay that makes sense thanks a lot for that
you can replace the antenna with a base model early 90s accord manual antenna if you dont want a powered one if you want to keep that factory look.
The mast? There is a special socket to take the retaining nut off. Or you can use two screwdrivers and apply appropriate leverage. I cant begin to explain how to do that. Then get the old one out. Turn on your radio. Stick the plastic bit of the new mast in the hole. Turn off your radio. The motor should grab it and pull the mast down. Put the nut back on. I haven’t done this in about 15 years so detail may be lacking.
