2010- Made 317whp 230wtq @ 13lbs of boost on 92 pump
Goal for 2011- 500whp - Currently @ 408/300 17lbs E85
My car wasnt running like i wanted it to, so i decided to pull out all the stops (as much as my wallet could afford anyways)
So im building my engine from the ground up with everything but sleeves, for FI, more specifically turbo.
Not only that, but this car will be getting worked at from all angles, including interior and a little bit of exterior work, not that it needs much, the car already looks how i want it to.
current modification list
Exterior
Oem Optional Lip Kit
15 Inch Konig Helium
205 50 15 BFG KDW 2
Led turn signals
Interior
Itr Shift knob
USDM ITR cluster
ITR Door Panels
Quad Pod bezel
Engine
Skunk 2 intake manifold
Port Flow stage 1 headwork
Ferrea titanium retainers and dual valve springs
Skunk 2 Valves
10:1 81.5mm Wiseco Forged Pistons
Eagle Connecting Rods
ACL Race bearings
ARP Head studs
Moroso Baffled oil pan
Suspension
Koni Yellow shocks
tein s tech springs
skunk 2 camber kit
ingalls torque dampener
Tein hood dampener
Transmission
competition stage 5 clutch
act 12lb flywheel
quaife limited slip differential
Electronics
Alpine deck
JL Audio tweeters and speakers
Fuel
Walbro HP 255LPH pump
B&M Fuel pressure regulator
B&M Fuel pressure gauge
Fuel injector clinic 1000CC injectors
Turbo Kit
Spoolin Performance Mini Ram
Tial 38mm wastegate
3 inch down pipe
Kteller 3inch exhaust
ultimate Racing 500hp Intercooler
SRE intercooler piping
Defi Oil pressure gauge
Defi Oil temperature gauge
Defi Boost gauge
AEM wideband
HKS SSQV Blow off valve
Stealth mode oil line kit
Parts on the way
Parts I need
- brake pads
- brake rotors
[b said:Table Of Contents[/b]] page 3- Dyno Graph and small mods
page 4- amber corners installed
Page 5- pictures and updates
Page 6- Full race Vacuum block ordered, tial purchased
Page 7- turbo purchased! 3 inch exhaust purchased!
Page 8- Boost gauge and updated with current news
Page 9- pictures of the gsr
Page 10- New plan of attack
Page 11- Pistons, Turbo Wideband
Page 12- Eagle Rods
Page 13- engine is out! bottom end disassembled and MOROSO PAN!
Page 15- clutch, vc, gaskets, axle, bezel
Page 16- engine and trany install
Page 18- more updates, exhaust!
Page 22- Random pictures & HIDS = ordered
Page 23- Couple of pix and video from tuning
Page 25- Droid Camera Action and mystery boxes
Page 26- 2010 Recap
Page 28 - new parts
Page 34- Tial 44mm wastegate
Page 36- fal, mishimoto, recaro, ngk, vibrant etc
Page 38- seats and blanket
Exterior
205 50 15 BFG KDW 2
Led turn signals
Interior
Itr Shift knob
USDM ITR cluster
ITR Door Panels
Quad Pod bezel
Engine
Skunk 2 Valves
ACL Race bearings
ARP Head studs
Suspension
Koni Yellow shocks
tein s tech springs
skunk 2 camber kit
Tein hood dampener
Transmission
act 12lb flywheel
Electronics
Alpine deck
Fuel
Turbo Kit
Tial 38mm wastegate
3 inch down pipe
Defi Boost gauge
AEM wideband
Parts on the way
Parts I need
- brake pads
- brake rotors
