Going to turbo the LS by the end of the summer '06.
I'm looking to do mid to low 13s in the 1/4mi, nothing special, and I want about 200 LBS of TQ to the wheels. The teg is an LS and I do not want VTEC, so my redline will stay stock.
Check over my idea for a setup if you would, all comments are welcome and appriciated.
*T25/28 Hybrid Turbo w/intcooler
*Internal wastegate @ 7psi
*2.5" through DP/Cat/Exhaust
*Vortec Inline HP FuelPump
*OBD-I and NepTune W/Boost
*Upgrade clutch somehow...
*Motor mount inserts
*LSD mated to LS Tranny
Other stuff to get good times- Short shifter, 16" Slipstreams w/good tires
Reason for T28 choice--
**Spool @ 2K, Peak Spool and TQ @ 6K RPM
**Need to keep A/C & P/S
I searched for T28 and found one thread that said too much heat will be given at redline, but that was for a high revving GSR. My car will still redline at 6.XRPM so I don't think that will be a problem.
Again I'm not looking to upgrade in the future or push more that 7psi on the turbo. This will be the final setup for a few years. Time goal is mid-low 13s, good Auto-X car.
Thanks all, boost with you soon.
