1 - 14 of 14 Posts
I just put altezzas on my car, and i guess they were tight enough or something, but there is water inside of the light and i was wondering how i could get the water out or if there is a way to dry it. Let me know Thanks
Take them back off, suck out the water with a vac and let them dry really good, then go down to your local part place and ask for wind shield sillicon sealent and seal those things up. Let dry for 24 hours and replace and you should be good to go for a while at least.
yes take out the light housing and wipe them dry. then what you could do is use a sealent on the eges of the altezza's so that water would not be able to get inthem anymore.
_________________________________________________________
"Take them back off, suck out the water with a vac and let them dry really good, then go down to your local part place and ask for wind shield sillicon sealent and seal those things up. Let dry for 24 hours and replace and you should be good to go for a while at least."
Use a hairdryer to finish drying.
91_Integz on Aug/28/02 said:
mine do that too....i tried siliconing around the edges.....it helped but i still get the condensation
you missed a spot somewhere, I also had this problem but they havent leaked since I sealed them.
1 - 14 of 14 Posts
