1 - 10 of 10 Posts
I just got an alignment done and this is what I got.
Before:
LFRF
-1.7 Camber-1.7 Camber
-0.5 Caster.7 Caster
-.53 Toe-.08 Toe
LRRR
-.7 Camber-.06 Camber
.22 Toe.19 Toe
New:
LFRF
-1.0 Camber-0.9 Camber
-0.5 Caster1.0Caster
-.01 Toe-.00 Toe
LRRR
-.8 Camber-.6 Camber
.06 Toe0.08 Toe
My question is the LF caster was red so I was wondering how bad is that and also the difference of the rear camber being .2 is that a bad thing?
I have looked in the articles and searched but I dont know how to convert the numbers in the articles to degrees. Thanks in advance.
As far as caster is concerned... It will not wear your tires out any faster than camber or toe would. I would say your fine although since you did pay for it they should have adjusted it.. unless your on modified suspension.
You cant adjust caster I believe unless you get a kit to adjust it with.
Quote: 95integraLS003 on Sep/18/07 Looks good to me! How does it drive? Any pulling to one side or bias on the wheel?
it was pulling to the left a little but the road was at a slight slant so I am not sure.
1 - 10 of 10 Posts
