The factory OEM oil pressure sending unit has only one wire that goes to it to run the idiot light now i am trying to replace that with aftermarket oil pressure unit so I can run aftermarket oil pressure gauge.
I had the gauge working as far as it light up but the oil pressure is not reading correctly as it does not change with RPM.
This gauge came with a 3 wire connector but since the OEM factory oil unit only needs one wire hooked to it then can't i just make sure signal wire is hooked to the oil unit?
The gauge side also has 3 wire connector so what would i need to hook to that just a run a 12v hot wire and ground from the gauge and then make sure the signal wire coming from the oil pressure sending unit is also connected to the gauge??
