i have decided to go with nitrous and what i want to know is how to build a good engine to use it on.
my engine (B18C)has to come out any way (head gasket leaking and gear box needs new sychros) so i guess now is a good time to do it.
what im after is and engine that will be good for up to a 150 shot but also still a good, quick daily driver
im in the u.k and its like being in the dark ages over here and i really need the help.
thank for any replies
Well then, look into some high CR forged pistons, new rods, ARP head studs and rod bolts, GE sleeves, balance, micropolish, and knife-edge the crank, bore the block out to 84-85mm, spot face and deshroud the chamber and valves, new cams(not sure which ones for a b17a), new valvetrain, standalone, direct port injection nitrous system, WOT nitrous switch, and lots and lots of tuning. Oh, don't forget a bottle heater, purge valve, and all the rest of the goodies for that NO2 setup.
