ok, you may think i am an idiot, but when it means to turn the distributor counterclockwise, does it mean turning it while it is on, the car that is? or does it mean to turn it off then do it and turn on and check. I have a 97 rs, and i tried, but the distributor bolts won't bolt up if i turn it... do you even have to turn then bolt or do you turn it while it is on and then return the distributor to the original position? The article did not clarify this, but up to this point, it was very helpful. Ok, thanks for any help!
