i f**ked up today very very bad! i was trying to ground my foglights and i was testing out bolts and i took out a bolt in the ac pipe and a lot of myst/liquid came out. a lot of the pressure left so it was kinda safe to bold it back and i did. my brother said it was my AC coolant stuff and he said now my AC is gone. can anybody tell me what i did and a way i can fix it?
What you did is discharge your refrigerant. I would say it's safe to assume your a/c system uses 134a refrigerant. Also, they use a special oil (ester I think it is) 134a systems are servicable by the owner and i believe that Wal-M*art sells a hit with the gauge and instructions.
yeh thats what my brother said. so where would i put the refridgerant? and i need the oil and 134a refridgerant? just making sure.
thank you for your help. i was so scared when it happened.
Well, you'll charge on the low side of the system, this is usually denoted by a somewhat larger fitting and a screw on cap with an L on it, dont worry, the kit wont fit anything but a L side fitting
