Hey ya'll new to the forum, and in desperate need of advice...nutshell: 1998 Integra LS, Stock 1.8 B18B1, Manual Transmission. So randomly one day a couple weeks ago my headlights seemed like they were dim, come to find out, it's only the driver side that's significantly more dim than the passenger side, and when I toggle the high beams, i loose the driver side headlight all together, but the passenger side functions just fine....so when driving at nite, my regular low beams are on I just have a dim driver side headlight, but when I hit my left turn signal, the windshield wipers turn themselves on, and if I toggle the high beams, and then hit my left turn signal, it won't make the 'click-click' noise that a turn signal indicator is known for... ALSO keep in mind nothing outta the ordinary occurs when I hit my right turn signal indicator, it clicks like it's not got a care in the world, and passenger side headlight, low and high beam works wonderfully, so 🤷🏻‍♂️....Please any help or advice I've got to get this vehicle inspected and my wife will be driving it, and I can't have her in an unsafe vehicle 😞 I'm at my wits end everyone....please help
i had a similar issue, it was the ballast rattling around not properly grounded.
it's mounted on the inner driver side fender area by the a/c drier.
remove the bolt and clean up the grounding area and tighten it down.
Outstanding, at least ive got somewhere to start ya know? okay now which ballast are you referring to? do you happen to have a photo to get me headed in the right direction, and thank you again for replying, you can understand the mind numbing frustration it's been dealing with this ridiculousness
