All you got was 1 flash. you didn't get anymore after that. Because in the Helms book 1 flash measn ABS pump motor over-run.
Probable causes;
1. Air mixed in the ABS brake fluid
2. Pressure switch stuck OFF
3. Open circut between the pressure switch and ABS control unit
4. Open circut in the P-SW circut between the pressure switch and body ground, ora poor ground
5. Drop inpump discharge volume
6. Leaking modulator unit outlet valve
7. Leaking relief valve
8. ABS fluid leakage
9. Faulty ABS control unit
