About three or so times, I've noticed my ABS light come on for a second and then shut off. My brakes work normally and the ABS will kick in just fine. The past times, the engine was idling, so I figured that maybe the idle just got a little too low (I need to adjust it; it's been around 500-600 rpm since I installed my header and exhaust). But the most recent occurance was different...
It did it yesterday as I was driving down a very bumpy dirt road. The interesting thing about that was that my V1 did it's power-on "ritual" at the exact same second, so it must have temporarily lost power. My stereo was on at the time but didn't lose power, and the engine seemed to be running just fine. Any ideas?
I know the ground on my battery is a little loose (the ground terminal is slightly smaller than stock and I cant make the connector any tighter), but I would think that if that got disconnected, the alternator would still be powering everything.
