1 - 16 of 16 Posts
So I have been shopping ALL day for a timing belt kit. Started at 400$ from Honda, then 300$ at my auto parts store, then I thought I was good to go until I looked online, 200$!!! wow, can't beat that!
Then I went to another site, they have a Gates timing belt kit (Water pump, belt, tensioner and spring) all for 99$, 125$ after tax and shipping, and supposedly gates is a reputable brand
It almost sounds too good to be true. I dare not post the website name since I do not want to appear as if I am advertising, but have any of you gotten ridiculous deals on Timing Belt Kits?
I am in Vancouver BC located in canada, and this website has a canadian name but it is in the states...... I can drive across the border to pick it up, no biggie, but I am amazed that I can get a Gates kit for so cheap...... Anything I should watch out for? I don't usually buy online
You shouldn't have any issues
I bought this kit off eBay (which was GMB parts and Gates belt) and it went on and works perfectly
Gates stuff is usually pretty good. I know a lot of people who have used the timing kits for their jettas, miatas, etc. I bought this kit for my own car but I ended up selling it to someone on here. The tensioner that came with the integra ls kit was a Koyo.
I just installed the Gates kit last December and haven't had any issues. Then again, only have 5k miles on it too!
Gates stuff is usually pretty good. I know a lot of people who have used the timing kits for their jettas, miatas, etc. I bought this kit for my own car but I ended up selling it to user aw614. No clue if he put it in yet. The tensioner that came with the integra ls kit was a Koyo.
I don't recall buying the timing belt kit off of you, just the rear sway bar.
Gates stuff is good. Well made in America. I installed a Gates timing belt kit with water pump in July this year when I got my new car. And I have been selling Gates products for the past 5 years, no issues. Quality stuff.
Discussion Starter #8
For the record I ended up buying off ebay.
GATES TCKWP184 is the part number, includes timing belt, water pump, tensioner and spring, not bad for 85$ including shipping :)
I hate to bring up an old thread, but I going to replace my cam seal due to a leak, and I figured i would do the Timing belt/ water pump etc. I have only 83,000 miles on my car, but I just got it recently, and I figure why not change it all at once. My question is this.
Is this Kit OEM and a pretty good deal? Is there a better option? I just thought is ask some opinons.
Integra Complete Timing Belt Water Pump Kit Japan 96 01 | eBay
or maybe this one
http://www.ebay.com/itm/AISIN-Water-Pump-Timing-Belt-Gasket-Kit-965-72027-Acura-Integra-GS-1-8L-97-01-/361269684065?fits=Year:1998|Make:Acura|Model:Integra&hash=item541d59e761:g:wJcAAOSwstxVLFcz&vxp=mtr
Or dhould I just change out the Cam seal and Valve cover gasket to fix teh leak.
at 84k, i'd be suggesting to be on the safe than sorry side and do it all... it's really all not "hard", just time consuming
a toss up between the kits, but i'd go with the first one you linked to
Tks for the reply.
I found this kit also. I figure one of these will suffice. Any other opinons
Complete Timing Belt Water Pump Kit Integra 94 01 B18B1 CRV 97 01 B20B4 B20Z2 | eBay
here is on i linked earlier
Im gonna try to learn to do this stuff myself. Should I get a thermostat while im at it? any other parts I should get while Im tackling this project?
Start right here:
Timing Belt and Water Pump Replacement on a G3 Teg - Team Integra Forums - Team Integra
it's definitely a part that fails and you will have the coolant drained anyways, it would make sense to do that.
Here is the walk through for that:
G3 Thermostat Replacement - Team Integra Forums - Team Integra
This site is great for learning how to fix your own car. I sure hope i can get this all done without messing something up :)
I for some reason opted to just get OEM parts since I would be saving on labor. here is the parts list I got. Did I get everything?
1. Water Pump part number# 19200-p75-003 $83.00
2 Timing Belt Part number# 14400-p7j-004 $55.00
3. Valve cover Gasket part number# 12341-PR4-A00 $15.50
4. Thermostat part number # 19301-paa-306 $20.00
5. Tensioner part number# 14510-p30-003 $21.00
6. Tensioner Spring part number# 14516-p4r-a00 $6.00
7. AC BELT/SERP BELT/ ALT BELT Part Numbers# 38920-PM5-A04, 56992-P72-004, 38920-P75-A02 $55.00 for the set
8. Cam Shaft seals X2 part number# 91203-PFB-013 $17.00 for set of 2
9. Front Main Crankshaft seal PArt number# 91212-PR3-003 $10.99
10. NOT OEM.. JDM password cam seal Black $18.99
So instead of a kit I could have gotten for 170 bucks i ended up spending a total of....
302.48 dollars!!
Ok sit down for this one....
I have two 98 tegs so I had to buy double of all..
98 ls non v tec 4 door sedan 271,000 miles ( owned for 15 years)
98 gs non v tec 2 door hatch 83,000 miles ( owned for 8 months)
604.50 I just spent on parts.. :driving:
I just thought Id put the part numbers up there and see what everyone thought about OEM vs Aftermarket OEM
I will say that I had the dealership do my timing belt/water pump on my 4 door sedan at 91,000 miles. I actually have not changed the Belts or water pump since then. So I basically have gotten 180,000 miles out of my current OEM water pump/ belt etc.
I'm not sure why, it would have made so much more sense to save $400 and spent that on upgrades/maintenance needs, but your $$ i guess
I sat and pondered getting the Cheaper kit with Japan oem style manufacturers, but I guess i just wasnt 100 percent sure on them
Honestly, I had an 01 Acura TL that had belonged to my Father and When he passed away, I was given his Acura TL. He took meticulous car of the car and always had Michelin Tires, and Higest quality parts for maintennce.
Anyway, I always babied the car and tried to take care of it. Sadly, I was rear ended by a cell phone driver and my Dads car was totaled. The insurance money is what I got my ACura Integra 98 Hatch with 83,000 miles with.
So in a weird way, i still feel like this Integra is somehow still my Dads Car so I guess I just wantd to try and put the best parts on it.
As far as my other teg car goes, I prob should haev gottent the cheaper kit and used the extra for repairs.
Oh well, im pretty happy i guess . Ill just have to work my butt off for a few weeks.
1 - 16 of 16 Posts
