1 - 1 of 1 Posts
Hey, new here. Looked around for a related topic, couldn't find one.
I have an impound integra picked up for $600 with no key, and my roommate tried starting it with a screwdriver... Lock cylinder is boned now. I had 2 keys cut for the car (chip and normal), got the cylinder removed, and picked up an ignition switch from a pick-a-part for cheap. The thing is, the ignition switch is from a 98, not a 00, so I'm not sure if the cylinder will fit in the switch, let alone turn with the keys. Will it work? Any help is appreciated.
(Side note: due to removal complications, the 98 switch may need the back rotating part in the bell end bent back in shape, but that's easy enough)
1 - 1 of 1 Posts
