1 - 1 of 1 Posts
I recently swapped my obd1 LS engine from my 95 integra over to my 98 and also did the obd1-obd2a ECU jumper harness. Before the swap I deleted all ABS, SRS, and cruise control. Mind you when I got this car is was stripped down pretty far so I had to install the fuse box under dash and find out where all the plugs go etc. My issue I am having is I have a few random lights on and it seems to be back feeding. Hes a run down of what it's doing. Turn signals work but indicate on the cluster that it's the opposite direction when it is not. Cruise control, ABS and SRS lights are on. I figured those would be considering I removed all those components from the car. My main question is the turn signals and both signals are steady dim on the cluster. Also when car is running and I hit my high beams the RPM guage will cutout. Also no backlight on cluster or climate control.
1 - 1 of 1 Posts
