Hey guys I have a 97 LS obd2a auto coupe that im trying to convert to 5 speed and obd1 at the same time. Now I have also recently picked up a 95 LS 5 speed obd1 parts car. Now my question is if I remove all the wiring harness's from the 95 obd1 cabin,dash,engine harness, and engine bay harness and swap it over to the obd 2 auto. Will everything be plug and play? I don't see why not only thing I keep thinking of is the obd stuff. OBD1 wiring In a OBD2 chassis???
I know u can just swap the 5 speed related stuff and do a little wiring and have it converted to 5 speed. Then throw a obd2-obd1 jumper harness on it.
Or I can swap over all wiring harness's and have the whole wiring system converted to OBD1 then install 5 speed stuff and everything will plug and play hopefully . Like reverse lights, clutch safety switch lil stuff like that.
Anyone have experience in this area?
Not sure why you're thinking that you need to install the full harness. Buy a simple OBD2-OBD1 conversion harness and be done with it. Nothing additional with wiring needs to be done with going from an auto trans, to manual trans
So just obd2a to obd1 jumper harness and 5 speed ecu? And of course all 5 speed related stuff installed.
