I just replaced the oil pan gasket yesterday, but this morning went to look and saw there’s a leak from somewhere above the oil pan, but it’s only while running. I’ve read some places it could be the oil cooling ring? Could it be the oil pump overall?
I’ve attached my post from reddit bc I don’t think I can post vids here.
https://www.reddit.com/r/MechanicAdvice/comments/myb8op
give the proximity to the pullies and its above the oil pan, i'm thinking theres a pretty good chance its that seal on the oil pump.
I also had a leak coming from above the pan, on the rear facing side. Mine is a GSR and so it was the seal behind the oil cooler which sits between the pump assembly and the oil filter.
I've also noticed some dry oil around the breather chamber, but have not troubleshooted. PCV breather chamber/box
