Hey guys
I'm getting ready to change out the bushings for my 97 Integra LS, and I've read the (horror) threads about the rear LCA bolts breaking so am planning to get new LCA bolts just in case.
I've followed the suggestions to PB Blast all the bolts so hopefully won't have bolts break off on me...
Even if none of the bolts break, would it be worthwhile to replace all of the other main bolts for the control arms while I'm at it?
I came up with this list below, would appreciate if someone could let me know if I'm missing any important ones or if some aren't going to be worthwhile to replace.
90172-SK7-A01 Bolt, Shock Absorber (LOWER) (10X84) x 2
90173-SR3-003 Bolt, Arm (LOWER) (10X80) x 4
90118-SR3-003 Bolt, Self-Lock (12X76) x 2
90120-SB0-003 Bolt, Shock Absorber Lock (10X42) x 2
90175-SH3-005 Bolt, Shock Absorber Fork x 2
BTW, I've been lurking around the forum for some time but just recently got into modifying our Integra (first owner since 1997, less than 103k miles).
The stock shocks have just gone bad so first thing will be doing is replacing them with some TEIN coilovers in addition to the bushings.
I know the OEM bolts are gonna cost me over $100, but we're planning to keep the car for however long we can, even if it means doing an engine swap, etc.
Thanks in advance!
Bolts only really break if rusted solid. If a bolt breaks loose OK there is no reason to replace them. Honda uses great hardware, I would spend my money elsewhere.
If your car is rusty, I'd recommend loosening with an electric impact driver. If the threads come out rusty, clean them up on a wire wheel.
Thank you @Whitney ! I just called my local Acura dealer to ask if they have these bolts in stock in case I need to get one replaced. Was thinking it would be cheaper to buy all the bolts online but I guess I'll save the money and spend it on control arms instead.
BTW, I've seen some good reviews with Hardrace bushings, but are their control arms worth getting as well? I can't seem to find any Function 7s anymore online.
LCA bolts aren’t too common to break, the UCA’s and compensator arms are a different story. I’ve just replaced all my stock bushings with polyurethane and the rear LCA’s gave me no problem at all. The rear Uppers and compensator arms I had to cut 3 out of the 6 bolts bc they had seized inside the bushing sleeves. You should be in good shape, factory bolts are expensive as hell from the dealer, I managed to get my replacement bolts from a local junkyard for free
Discussion Starter #5
Wow, thanks @Kevin311 that's good to know. I'll make sure to PB Blast all those UCA and compensator bolts as well before trying to take them out.
Somehow I've heard quite a few instances where the LCA bolt broke off or got seized and had to be cut off, but I'll see if I get lucky...
