1 - 2 of 2 Posts
Have B18B1 needing an ECU, I am new to this, the dude I got it from said it needed to be OBD1 what are the recommendations for an OBD1 ECU and what P # does it need to be? It has RyWire Harness as well.
If anyone would like as well in need of Headers if you would like to make a recommendation on that as well.
Thank you in advance.
P75-A01 for the ecu. The part numbers are the same for obd1 & obd2. So you have to look at the connectors. Many pictures on line. An obd1 92-93 Pr4 ecu can work as well. But the 94-95 P75 will work better.
My header recommendation for a B18b1 would be anything tri-y or 4-2-1. If you go with a 4-1 design you will loose low to midrange torque. Which is where most of the non-vtec engine shines.
1 - 2 of 2 Posts
