question so my 96 teg is having some issues rn and i can’t seem to figure it out so it won’t start up unless it’s jumped so i put a new alternator and a new battery and still nothing. but the thing is that when i jump it it will run fine in idle and surprisingly in reverse too but as soon as i put it in drive it starts puttering and will move a couple feet then die. the guy that i bought it from said it’s the b line but i’m not sure. any ideas?
Check and clean the ground cable under battery. If its funky back the bolt out and get a small steel wire brush and cleaner up.
Then spray everything with wd40 and reassemble. That's my 1st guess.
Do you have 12 volts everywhere and the lights work / bright not yellow. Another sign of bad grounds.
GLWR keep us up on whatcha find.
H. M.
