1 - 20 of 752 Posts
Post 1: Parts For my Build (Stock Motor)
Post 2: Pics Of TI meet before Build
Post 3: Turbo Parts Buying Begins
Post 4: Begin Install of Kit/AFAP Racing (Stock Motor)
Post 5: Updated with Pics/ Install (Stock Motor)
Post 6: Install FMIC/Inject/Exhaust/etc
Post 7: More Install and Things to watch for/AFAP Racing
Post 8: Updates of Install/Fab work (Stock Motor)
Post 9: Finished Fab work/In car view/Shifter bushings/Painted CP
Post 10: Update Oil Return/DP/Testpipe/New IM
Post 11: Installed IM/Fuel Rail/ Test Pipe A look at our work area :)
Post 12: Locking down and Prepping For Sat (Dyno)
Post 13: Wideband/Gauge wires/Fabbed water temp unit
Post 14: Night before Tune
Post 15: D-day - 268 whp/ 209 lbs-tq
Post 16: Video of first drive w/ tuner (street tuning)
Post 17: More Parts in for next Phase :)
Post 18: More Parts w/ pics for next Phase
Post 19: New parts: Progress Suspention/LCA's/ JimFab torque mounts
Post 20: Cracked Sleeve -> Built block plus all of phase 2 parts
Post 21: Stock Blown motor removal and Carnage 1
Post 22: Close up carnage shots and clean up
Post 23: New Motor comming together
Post 24: New Motor comming together Part 2
Post 25: New Motor Flywheel/clutch/tranny install
Post 26: Motor back in car!
Post 27: Almost Done!
Post 28: Ready For Break In/tune
Post 29: Startup/Break in
Post 30: Ready to be Dropped off
Post 31: Update and work on a Type-R
Post 32: Update from the shop
Post 33: Smoliga / Slicks + street tune
Post 34: Indey Race Way Weekend Extravaganza
Post 35: Cluelessmale (brian) at MIR
Post 36: New Vids Of My Teg
Post 37: Track Prep/Slicks Issue
Post 38: Mikes All Motor Track Cage
Post 39: New Parts/AFAP Update
Post 40: Parts in and a view of Synapse
Post 41: Update From Synapse and New Rota's
Post 42: Pictures of Synapse and pics from show
Post 43: Dyno Chart = 340whp/280trq
Post 44: Emissions = PASSED
Post 45: DR's and updates
Post 46: Prep and Rainout at Dragway *SUCKS*
Post 47: Scattershield & Drag Radials
Post 48: Racing at Atco and Interview
Post 49: Lebanon, Atco Pictures and Timeslips
Post 50: CT Local Meet
Post 51: Trashed Transmission
Post 52: New Transmission & How to Open Trans Case
Post 53: Teaser shots of AFAP Racings New Setup
Post 54: Suspension fix and Optional Sides test
Post 55: Dyno Tune 325whp/265trq *Vid*
Post 56: LS For Sale / AFAP Racing Hot Rod build
Original Post:
Turbo Things I have:
-RLD ramhorn exhaust manifold (coated)
-Garrett t3/t40e 57trim turbo .60/.63 (hotside coated)
-3” downpipe
-Edelbrock Intake mani
-Tial 50mm BOV (w/9lb spring)
-2.5” charge pipes w/tial bov mount attached
-tial 38mm wastegate
-hasport (race) motormounts
-walbro 255 intank fuel pump
-JRC FMIC 2.5" inlet/outlet
-RC 440cc injectors (which i have)
-AEM Wideband 6-1 UEGO Gauge
-JK tuning (chipped ecu)
-Thermal 3" catback exhaust
-gauges (Boost, water temp, 2 oils(one for motor, one for turbo)
-adjustment valve for oil pressure to turbo
-Vibrant Couplers & T-bolt Clamps
-VAC lines
-oil line/return line
-3” testpipe w/o2 bung
-dumptube for wastegate (custom)
-chipped ecu for neptune tunage
-.028 gapped sparkplugs
What's ahead:
-LSD in gsr tranny
-Full race traction bar
-Slicks
I was offered a 98 gsr tranny for 600 bucks with shift linkage (no lsd)... havent really researched prices but it seems high.
This setup is for DD and for drag use..
Any suguestions, comments, questions...
New Post:
Updates are on Later Pages Check the links above!!
Updated Mod List: (as of 12/18/2007)
Motor:
-Stock LS head
-LS with Eagle rods and Wiseco pistons (stock sleeves)
-3” downpipe
-Edelbrock (polished) Intake manifold
-Tial 38mm wastegate
-Hasport (race) motormounts
-Walbro 255 intank fuel pump
-Precision 1000cc injectors
-FJO Injector Driver
-Aeromotive FPR
-Custom 750core FMIC
-PWR half size dual core radiator
-VAC lines
-NGK BKR7E11 sparkplugs (gapped to .027)
Transmission:
-GSR tranny w/Quaife LSD
-Action 2md clutch
-Stock Flywheel
Interior:
-gauges autometer (Boost, water temp, 2 oils(one for motor, one for turbo)
-JK tuning ECU (Containing Neptune)
-Sparco 5pt race harness
-B&M Straight short throw shifter
Sound:
-Pioneer 3.5" 3 way speakers all around
-Alpine Type-r Subwoofer in custom enclosure
-Sony 1200w amp
Exterior:
-PIAA foglights (painted color of car)
-Mesh grill
*To Be Installed*
-OEM Optional SideSkirts
-98+ Rear End
Suspention:
-Progress Coilover Race Suspension
-Blox rear LCA's
Tires:
Winter - Steelies with Goodyear allseasons
Summer - Rota SubZeros 16" with Falkin Azenis
Track - Lenso 13" wheels w/ MH Slicks 24.5x8.5x13's
Looking to Buy:
-looking to buy matching Lenso Skinnies (exospeed)
carnz98gsr on Jun/03/06 said:
dont quote me on this, but i think that if you ran your stock injectors, you could drive down to Evans, just make sure you dont go into any boost. just having the turbo installed shouldnt hurt anything.
If you hit the freeway, you're gonna come outta vacuum, or at least get damn close.
You can run the car on stock injectors making sure that the intercooler pipe is disconnected as you drive to jeff evans. I've done it MANY times before. At the shop that you tune, you can then put in your injectors at the time of dyno. You will not "overspin" the turbo and as long as you keep yourself under control, you'll be fine.
This is Nate's boy, some pieces he snagged off of kids used but in almost mint condition, some are new.. depends on what he could get. It all depends upon how much your looking to spend. He is already over budget but for the parts he bought they were better then what he was planning on getting. Ill call him get him on here...
Discussion Starter · #13 ·
Thanks J-dawg! Yes ive been pieceing this kit together for over a year. Some parts were found used on here, HT and a few other sites and then NOLIMITMOTORSPORTS helped me out greatly. We should see if we can pick them up as a sponser. Parts were next'd day'd to me. which was sweet!
TheShodan (turbomaster) - ive read a lot of your other posts and you give a ton of great feedback and great advice, i would trust the possibility of driving like you said but my boy has a trailer with a power'd wench so were prob just gonna use that.
Azpoolz - take your time and search for good parts, if you have to spend a little more to get the quality stuff i would suggest it...
A little sneak peak for everyone...
YUMMY..
Mani before #1...
Mani before #2...
Mani fresh out of the shop... (special coating)
Ill keep updating with parts as they come in and as i get them up!
Bling!
What did they dip the mani in? Chrome? :p
Discussion Starter · #16 ·
k3nny- They dipped it in a material to help dissipate heat. It looks crome but its a silverish color. When i go to install ill get better pics of everything!
CryFarKilla - What setup does your buddy have? how many lbs of boost is he running and does he have a dyno sheet?
This project will be on going, i want to get it up and running for now and i will add it more goodies later, but there are more important things i want to focus on before i just go all out on my car. I will own this car for a longgg time comming and hopefully i will be able to join my buddys race team down the road. We will see its still a ways down the road. Thanks for the comments fella's.
Discussion Starter · #18 ·
Yep between me and my friends we have spent the past year and within a weekends time we can have a car up and running..
We did his DD during spring vaca in 2 days. His other car is the monster drag car that is comming along quite well.
Im awaiting a few little parts and for my oil lines to be made and then it should be setting up a day. But i dont think its going to happen until the july'ish timeframe.
I stay far far away from anthing that remotly made me think it was ssautocrap... i spent a little more then i wanted but it was all for the better. And its should last me way longer then just one day...
i love seeing builds like these, makes me feel better about going turbo with my LS knowing theres people out there to help...
how much did the mani cost you to get it dipped and what was the material used ?
Discussion Starter · #20 ·
Im not sure of what material it is but it was about 300 bucks for the exhaust housing and mani to be dipped and what a difference it makes... i saw it for the first time in person today.. all i can say is AMAZING!
Turbo teardown begun today. I got everything off, Ac and radiator is out, the exhaust header is out, all old motor mounts are out, Safc2 was pulled, Autometer A/F was removed..
Hastport race mounts are in, Manifold was test fitted, Walbaro 255 fuel pump is in, Oil pan was marked for oil return line, oil lines were partialy built, parts were ordered(couplers, t-clamps, 3" thermal exhaust, water temp gauge, boost gauge), we made a homemade vac unit like golden eagles... (ill post pics later)
I forgot my camera but i should be returning up there in the next few days.
Thanks to my AFAP Racing LLC Crew they are the best! Shirts, hood spacers, and vac units will be up forsale soon!
BTW this is our main car for our AFAP Race team... (a lot more has been done since this pic)
Enjoy!! Ill keep updates as i work on my car!
1 - 20 of 752 Posts
