Okay so my car turned off by itself almost 2 weeks ago and I have checked if I had fuel pressure and I do have fuel pressure and my pump makes the sound when I turn my key and I was getting spark but poorly spark and it was kinda red so far I have changed my injectors, the ignition coil, and today I changed the ignition distributor and the car won’t start and I think it could be my ecu I really need help before buying another ecu.
I would take the ECU out and get it tested at the dealer if u don’t want to buy a ECU or find someone to test it
Yeah, test the ECU first... When it cranks, is it actually cranking? When my Tbelt went, mine died, too, so be careful in case that's it. easy to check, if you pop off the valve cover.
