Located in Tucson, AZ
$2500 cash
I am moving next week so need to sell quickly..
Its a rebuilt title from WA
It leaks oil if driven for awhile because the oil pan gasket is bad. It drips on the down pipe from the exhaust.
Car has 141K on it but motor only has less then 3K
The car is on the trailer because I took it out of town to try and sell and didn't want to drive it, it runs and drives fine.
Car comes with extra's: Carbon fiber hood, Polyurethane front bumper, hood pins, O2 sensor, Stock headlights, 525cc injectors..
First the bad....
Has a rebuilt title from WA
needs paint (clear coat is pealing)
dent in driver side fender
frontend needs fiber glass work
needs new oil pan gasket (leaks oil)
needs Tuned
No A/C
The Good....
Nissan S15 headlight conversion with true JDM Silvia headlights
Block bored out to 81.5mm
JG SRP 8:1 pistons
Eagle I beam Rods
ARP head Studs
LS head was port and polished with 5 angle valve grind
T3/4 turbo
AEM fuel rail
adjustable FPR
Block was bored over to 81.5 MM
Eagle deck guard
Glow shift gauges (boost, volts, A/F ratio, oil pressure, water temp)
Oil sandwich adapter plate
18" motegi FF5 rims
Neuspeed race springs
upper front and rear strut bars, lower rear strut bar, C pillar bar.
4pt race harness for driver seat
JUN chipped ECU
Exedy stage 2 clutch and pressure plate
Fidanza 7lb flywheel
NRG quick release steering wheel
$2500 cash
First the bad....
needs Tuned
No A/C
The Good....
JG SRP 8:1 pistons
Eagle I beam Rods
ARP head Studs
T3/4 turbo
AEM fuel rail
adjustable FPR
Eagle deck guard
18" motegi FF5 rims
JUN chipped ECU
