I've got LOTS of misc parts for a 94-01 Acura Integra. These mostly came off of a 94' and a 98' Integra GSR, although most 94' parts will fit 94/95 and most 98' parts will fit 96-01. Selling these all now because I'm leaving for school next fall and don't want them to keep taking up space in the shop while I'm gone. Parts are all in varying conditions, additional photos can be provided at request. Fair prices OBO for everything, there's too much for me to price everything individually. Anything not sold will probably end up in a landfill. All parts will be well cleaned before being sent out/delivered/picked up!
FULL part list:
-96'+ P72 OBD2-A ECU
-NEW IN BOX aftermarket 96+ blackout front blinkers (will trade for 94/95 blackout blinkers)
-OEM amber 96+ front blinkers
-Aftermarket carbon fiber pattern "Acura" seatbelt cushions (L/R) -Aftermarket "HKS" muffler
-Pop-out cup holders
-GSR strut tower brace
-96+ front bumper
-L/R OEM side splitters
-94/95 OEM rear bumper (preferably not available until summer)
-L/R OEM doors, both come with 94/95 harness (preferably not available until summer)
-Dashboard w/ side vents, buttons, and 94/95 sub-harness. Small cracks at the base of the windshield part, not visible from inside the car
-Leather GSR rear seat bottoms w/ seat belt buckles
-Cloth GSR rear seat backs, no included seat carpet
-Non-GSR front driver's door panel (no tweeter speaker)
-Non-GSR front pass. door panel (no tweeter speaker)
-Grey LS front driver's seat
-Grey LS front pass. seat
-Full 96+ carpet, several stains and one small tear in the pass. footwell
-Door sill plates (mount into carpet)
-Back trunk interior trim panel
-Rear hatch interior trim, all pieces
-L/R door frame trim (rubber piece that goes around the pinch weld)
-L/R trunk side trim panels (w/ all removable covers)
-96+ Climate control unit (functions on 94/95 but has different decals)
-96+ Upgraded central crash supports (you'll need these to use a 96+ carpet or rear seats in a 94/95)
-Aftermarket 94/95? headlight housings (may or may not be functional)
-OEM 96+ headlight housings
-94/95 driver's side knee panel (fits 96+ but has the wrong fuse box diagram)
-Center console trim
-Center console foam (goes under trim/carpet)
-OEM headliner w/ rear rubber trim piece
-L/R B-pillar trim
-Moon roof frame, glass, motor, trim etc. sold together or separately
-Washer fluid reservoir
-Front pass. wheelwell splash guard
-Steering column cover/trim pieces
-L/R interior door handle trim
-Handbrake handle (black button)
-Front bumper mounting plate
-Pass. side rear bumper crash foam
-Blower motor assembly (needs resistor)
-Heater box assembly (needs brass heater core (or just bend the pipes back into being round))
-A/C Evaporator assembly
-Glovebox
-Driver's kick panel
-Pass. kick panel
-Non-vtec, low mileage manual trans gauge cluster w/ broken glass (116,628mi)
-Non-vtec, low-ish mileage manual trans gauge cluster w/ intact glass (123,114mi)
-2x oem 12v battery trays
-Driver's knee panel folding coin pocket
-Set of 2 front wiper arms
-Blinker steering column switch
-Wiper steering column switch
-Hazard blinker button (no bulb)
-Rear defroster button (no bulbs)
-Knee brace support
-96+ gas flap lever
-96+ gas flap lever trim
-Driver's foot rest -94/95 driver's airbag
-94/95 pass. airbag
-94/95 cruise control buttons/trim (can swap circuit board to make them functional on 96+)
-AC Intercooler
-Articulating steering column brace
-L/R front visors (I think for 94/95)
-L/R OEM rear speakers w/ sound-deadened brackets
-Front hood latch
-Cigarette lighter/ash tray assembly
-Rear engine mount bracket
-Antenna assembly (good motor, bad worm gear. Aftermarket gears are ~$20)
-96+ Fuel pump/sending unit
-Front wiper motor/wiper assembly
-Mid-car brace? (bent sheet metal piece that goes over the gas tank inside the cabin)
-Passenger fender mount bracket
-On-engine P/S hose bracket
-Clutch slave cylinder (used briefly, thought it was defective but the problem was something else)
-Steering column U-Joint
-OEM headliner grab handles (broken plastic trim pieces around the mounting points)
-96+ Charcoal canister
-96+ Under-dash fuse box
-Front bumper plastic crash blocks
-Pass. dash mounting bracket
-Driver dash mounting bracket
-Gas-brake pedal assembly
-Clutch pedal assembly (no rubber pad)
-Dashboard support structure
-94/95 Cruise control ECM
-Glovebox brace/bracket
-OEM ECU cover panel
-94/95 steering column w/ lock cylinder and clockspring assembly
Local meetup/pickup/delivery available if you're in Pennsylvania. Located near Mount Pocono but I can deliver anywhere from Easton to Scranton. Can also ship at buyer's expense.
