Will a 93 GSR master cylinder fit a 90 teg RS ?? Or do i need the booster and does everything line up and bolt on ??????
You can bolt up the '93 GS-R MC to the '91 if you do the following:
Change the brake booster (slightly more travel and larger bore on the piston going into the booster)
Also.. I think you need to replum the lines in the front as the hard lines come off at different locations.
It isn't impossible to do but by no means will it be a direct bolt-on project in an hour or so...
HTH
Andrew
aka neex.
