well its for sale...I sunk a lot of money into this build thinking I would keep the car longer but in preparation for the future i know ill need something with 4 doors. I have ~$23k into this car. I really tried to buy top-notch parts when i did this build. Everything was installed on the car during 2017. I drive this car daily without any issues.
asking $10,000 obo.
The bad: car could use paint on a couple panels (fenders), rust repair on the rear hatch caused by the oem spoiler, no a/c, passenger window motor is getting tired but still works.
The good: car runs great and is a blast to drive. ready for scca auto-x or hpde track days. Still have the full stock interior to replace if so desired (front seats/rear seats/rear panels).
Engine/Trans:
2004 RSX-S K20A2 w/ 6sp Transmission
ACT Street-Lite Flywheel (11lbs)
ACT HD Clutch Kit (AR1-HDSS: 255Ft/Lb Capacity)
K-Tuned Ram Style Header
K-Tuned Throttle Cable & Bracket
K-Tuned Shifter Cable Grommet
K-Tuned Adjustable EP3 Pulley (Not Used Since Power Steering Install)
K-Tuned Universal 3" CAI w/ Velocity Stack
K-Tuned RSX Billet Shifter w/ Shifter Stops & Race Spec Shifter Cables
K-Tuned IAT Adapter
Hush Performance Cable To Hydro Setup
Innovative K-swap Mounts (75A Durometer)
Thermal R&D 3" Exhaust
Insane Axles Intermediate Shaft (500hp)
02-06 RSX-S Driver Axle (Insane Axles 500hp Rating)
06-11 Civic Si Passenger Axle, Spare Insane Axles k-swap passenger
Jackson Racing Power Steering Pulley (p/n: 052-154) w/ Summit Racing Belt (p/n: BAN-7PK1320, 7 Rib/52.00in Length)
Fuel:
Karcepts Fuel Rail
AEM Fuel Pump 320LPH, E85 Compatible (50-1220)
Aeromotive A1000-6 FPR
Aeromotive Inline 40 Micron Fuel Filter (SKU:12348)
RDX Injectors
Misc AN Fittings to 3/8 in Hose Barbs
Jegs Fuel Pressure Gauge
Cooling:
Mishimoto RSX Full Size Radiator (2 core)
Mishimoto RSX Fan Shroud w/ E-Fans
K-Tuned RSX Silicone Hoses
K-Tuned RSX Fan Switch
K-Tuned Coolant Temp Sensor
K-Tuned Temp Sensor Adapter
K-Tuned Heater Hose Adapter
K-Tuned Bolt On Radiator Stays
Suspension:
Ground Control Special Purpose Coilovers 550F/450R lb/in springs. (consist of custom valved Koni yellow shocks, extended top hats, bumpstops, 94-01 integra front shock forks)
K-Tuned Traction Bar
Hard Race Front UCAs
Hard Race Full Bushing Set
Hard Race Rear Camber Arms
Hard Race Rear Toe Arms
Blackworks Racing Billet Rear Lower Control Arms
Wheels:
15x7+35 Enkei RPF1
205/55/15 Yokohama S-Drives
Karcepts 36mm Kswap Hubs
LS Meshies (full set)
Brakes:
ITR Front Calipers
Mini-Cooper Front Rotors (280mm, non-s cooper)
TSX Front Pads
RSX Rear Calipers
EP3 Si Rear Rotors
Electrical:
Rywire K-swap Adapter Harness
Hondata Kpro v4
K-Tuned Engine Harness
Prosport JDM Style Oil Pressure Gauge
Prosport JDM Style Wideband Gauge
Ultragauge EM+
Other:
StrutKing Pedal Covers
Hybrid Racing Power Steering Conversion Kit
Corbeau Forza Seats
AutoPower 4pt Race Roll Bar
G-Force 5pt Cam Lock Harness
Seibon CF OEM Style Hood
NRG 320mm Steering Wheel w/ Quick Release 2.0 & Hub Adapter
Acuity BPST to NPT Adaptor (Not Installed)
Blox Oil Filter Relocate (Not Installed)
asking $10,000 obo.
Engine/Trans:
K-Tuned IAT Adapter
Fuel:
Karcepts Fuel Rail
RDX Injectors
Cooling:
Suspension:
Wheels:
15x7+35 Enkei RPF1
Brakes:
ITR Front Calipers
TSX Front Pads
RSX Rear Calipers
EP3 Si Rear Rotors
Electrical:
Hondata Kpro v4
Ultragauge EM+
Other:
Corbeau Forza Seats
