Any one know what 92-96 Prelude 2.3 non vtec injectors are? What size (CC)?
Thanks
Use more descriptive thread titles in the future. Simply writing "injectors" is not acceptable.
Dan 290cc were the 98+ ones. The older ludes were P&H injectors that used injectors. Most likely in the 300 range somewhere. I'm sure it could be found easily with a google search.
Taken from my "master list"
1992-'96 Prelude Non-VTEC Peak and Hold 240cc
1992-'96 Prelude VTEC Peak and Hold 345cc
1997-up Prelude VTEC H22 Saturated 290cc
A cheaper alternative, yes. However, being that they are used, you run the risk of them not flowing at the specified rate- if they are dirty, etc. You can get them cleaned, but by that time, might as well just buy some brand new, guaranteed to flow at the specified rate RCs... The RC310s work great, and you can get them Saturated and not have to worry when upping fuel pressure.
Of coarse, if you go with the 345s, you will need an injector driver/resistor box.
