1 - 20 of 56 Posts
New to the site. Cut my teeth on Hondas in 2004. Left the Honda scene around 08 and bought a Nissan. Sold the Nissan in 2014. Decided to hunt down a Honda to build last summer. Finally came across something I felt like was a fit. I originally wanted a DC2 but after 6 months of looking I made a last minute switch to the 2nd gen. I loved my old 92. DA coupes are beautiful. My wife named it Swiss Cheese because it's got hail damage to it haha.
It's a 91 LS with a 97 b20 swap. Will definitely be doing a vtec conversion but still undecided about turbo. I happen to like all motor a lot. Theres tons of stuff to do to this thing due to the 280k odometer so lots of updates will happen. It will be a while before it's slow posting.
105493
105494
Discussion Starter #2
Had a power steering leak from previous owner. They had the both the belt and pulley off to... I dunno really. I guess they thought it would lower the pressure in the system and reduce the leak. Anyways, there was old fluid everywhere in the bay. My looped the steering on my old DA so no biggie. Pulled all that mess out. It's for sale for cheap if anyone wants it.
105495
105496
105497
No idea who painted the bay gold but its really bad. Going to have to pull the motor and repaint it white. That will come in time. It's not my daily (first time in my life I can work on something I don't have to drive) but I do want to keep the projects within reason. I don't want 2 years to pass in between drives. So one project at a time hopefully.
Discussion Starter #4
Cruise doesn't work but I plan on tracking this somewhere. Probably road course mostly, but def a trip or two to the 1/8 or 1/4. Pulled windshield washer tank and the gross strut bar too.
105498
105499
105500
Discussion Starter #5
These wheels are super puke so I'm selling them. Did manage to score some fat fives for low though. They need some work but it'll be worth it.
105501
105502
Discussion Starter #6
Can't wait to install these. This was the first actual item I bought for the car. It rides awful. The whole suspension needs done so this will be a big upgrade.
105503
Discussion Starter #7
Can’t wait to get these bushings in. I’ve never done the master kit so this would be tight. <<—-pun
Discussion Starter #10 (Edited)
Did a lot in short order today. Dropped off the upper control arm mounts to get pressed out and poly bushing pressed in. I have a feeling the labor is gonna be a rip. So I figured I could set up a vise and get some stuff out myself. 32mm socket works good for upper ball joints.
105515
and since I was in the building listening to 311 (I know 3/11 day was yesterday but I figured it’s Corona Virus judgment day so might as well make it 3/11 week) I am required to drum along.
105516
Also, I picked up some Skunk2 lowering springs. They came with struts but I ended up switching them to the struts that were already on the car. Just a tad more resistance on them. Both sets of struts are blown like a mug anyways.
105517
105518
Discussion Starter #11
As I figured. $40 for this guy to put these bushings in. That’s basically half hr of labor when I know it took longer than that. Whatever. Just waiting on the ball joints to get here and the upper arms are done.
105519
Discussion Starter #12
Had to get creative on the lower control arm bushings. I was able to get the rubber out but not the metal outside race. So a hand saw worked but detaching the blade and putting it into the bore and sawing two cuts. The. I just used a chisel and hammered the pieces out.
105521
The new bushings went in pretty easy with a bfh. I put the new sleeves (inner race) in after the bushings were in. Made it a little easier.
105522
Discussion Starter #14
Finished the remaining 2 bushing on the LCAs and got the new ball joints in the spindles/knuckles. I’m going to see how long these trash eBay ball joints hold up. They have the energy bushing on them but they’re basically dust covers. So whole right side done. But left side needs a cv boot repair before I can finish it.
105523
And it’s a holiday that I am not sure why I celebrate, but Happy St Paddy’s Day.
105524
Discussion Starter #15
God knows how much I hate cv axles. They are just bastards. This one of course came apart and now the section that connects to the half shaft is all that’s left. I’ve tried all the tricks so I can I’ll probably just leave it and put the new shaft in minus that section.
105535
105536
Discussion Starter #16
But on a more positive note, got the tail lights in with the new gaskets. Look better than the old ones to me. Also started sanding down the rear midsection to see how bad the rust is. It’s all the way through in spots. I’ll either fill it or pull the one off this roller I’m buying next week.
105538
105537
105539
ah so now i see the swiss cheese part lol. Is that the worse spot on the car? If so, thats not bad at all. you might even be able to tack weld that shut. and bummer on those axles, thats a PITA to deal with. Is it just seized in the tranny, like the clip won't release?
Discussion Starter #18
Yea it’s seized in the half shaft. The clip is not collapsing allowing it to pull or something. I’ve used breaker bars, vise grip, and a slide hammer made out of an old vise grip. Such a pita. Also the car has hail damage along with those rust spots. So the Swiss cheese is on point lol.
I wonder what made it start there, seems like an odd place for rust to start. I guess maybe installing or uninstalling a taillight once and accidentally gouging the paint through to the metal is all it would take though.
1 - 20 of 56 Posts
