Hey everyone,
I looked through the other posts regarding the 60,000 mile maintanance, and found the list of things that need to be done, I also called the dealership here and they said they would charge $475+ tax for it. I asked if the timing belt, water pump, plugs, and cap need to be changed and he told me that needs to be done at 105,000 miles. I am really confused on what I need to do, I dont have a manual either so I am not sure what to do. Here is the list of things the guy told me and also that I found on the posts in here:
Change engine oil and oil filter
Inspect fluid levels and adjust
Inspect tire pressure and adjust*
Replace air filter*
Replace engine coolant
Inspect front wiper blades*
Inspect exhaust system for leaks
Inspect drive belt condition and tension
Inspect condition of coolant hoses
Inspect CV boots for tears or leaks
Inspect steering linkage for wear
Inspect brake linings for wear
Inspect horns and lighting for proper operation*
Inspect battery condition & battery cable connections*
Lubricate suspension, latches and hinges
Rotate and balance tires*
Install MOA oil life extender
Perform fuel induction service
Perform transmission fluid transfusion
Also, I just got a new radiator cuz it busted, so I dont think I need to do the coolant stuff. If anyone can please help with some info that would be awesome! thanks
Replace air filter*
