ok after reading the articles on compression testing...
they say to take out the 15amp fuse for the fuel injection system....,
and to 'unplug the power connector to the distributor'....
so which plug would that be? there is a two prong plug and a 6prong plug going to the distributor? which to unplug?
finally hipotetical question...instead of cutting the fuel and distributor power couldnt i just run a wire directly from the battery to starter motor to crank the engine a few times to get a reading?
anyone know compression readings for a b16a2?
