1 - 14 of 14 Posts
Will this size of tires fit on an integra lowered 1.8f and 1.5 rear. would this be a problem .
thanks for replies
ur better going with 205/45/16, not that the 40 series is a bad thing its just ur speedo will be out
Check this out.... So it will depend on what your doing with the tire.
23.3 is the stock 195 55 15 for GSR.tire rack
so 215-45-16 is what you recommend. Will those be a little to thick so when I turn theyll rub. If so I dont want that . Thats why Im considering 215-40-16
205 45 16 would be closer to stock and would have less chance of rubbing.
IS anyone running this tire size on their teg. 215-40-16
I ran 205/40/16 with a 2.25 fr/2.0 rr drop and had no rubbing issues. 215/40/16's are only about 1 percent (8 mm) taller than 205/40/16's, so with only a 1.8 fr/1.5 rr drop I am certain you'll be fine.
A 215 is also wider!
I ran 205 45 r16 potenza. perfect fit especially with turning. I now run the 205 40 R16 and i feel like its a big down grade cause my turning sucks balls because it feels like i dont have any power steering. but yea, run with the 205 45 R16
I've had 205/40/16, 205/40/17, 215/40/17, and 205/50/15 tires on my car. By far I like my 205/50/15's the best. But if I bought 16's again, I would get 205/45/16 tires because I think 215/40/16 is a litte wide and a little too low profile. Trust me, if there's a lot if potholes around your area, 40 profile is gonna suck.
1 - 14 of 14 Posts
