I bought my daughter a 2001 Integra GS. It started having problems starting. It runs perfect, no power loss. Every so often it just won't start. It cranks great. We installed New Distributor, Crank sensor, fuel pump, valve adjustment, spark plugs, spark plug wires, fuel filter, & air filter. But the problem is still there. Runs great, just won't start sometimes.
Your symptoms are inline with a common issue with the Main Relay. Here are some existing threads with regards to this:
Search: Main Relay
Have to dive in a little deeper, to determine if it's not getting fuel, spark, or a possible combination of both. Do you know how to check for fuel and/or spark when the issue is occuring?
Discussion Starter #5
It's going to the shop Wednesday. They think it could be an ignition issue in the column.
