It's been over a year since I got the car and the worst issue I've had so far is the brake switch going out, I drive it daily. It sits at 208k as of today and runs great aside from some minor idle issues. It's been a little hard financially this year, but I've done my best to maintain it and do some minor "mods" with what I can afford. I recently got a job at a Honda dealer leading to my finances improving, it's time to get back to working on it.
So far I've had all fluids flushed (Coolant, Brake, and Clutch), replaced the oil pan gasket, better tires put on (tread wise), new rotors and pads, replaced brake light switch (I hope I never have to again...), done two alignments (all is good aside from caster being slightly out upfront), replaced the shifter with matching OEM one, re polished the headlights, and replaced all the spark plugs. I've done only 2 "mods" which are not at all performance related, that being a Type R replica spoiler (I know, but I really love the way the car lines flow with it), and a Yonaka Axleback which I will be realigning by a good shop this week. I'm planning to keep on maintaining and restoring it this year as much as I can and keep it OEM where it needs to be. I've done everything myself, including alignments as this car has been helping me learn a lot in the automotive field.
I have some main goals to try and accomplish this year. Doing a full timing kit with a water pump (all OEM, I've been slowly stocking up parts) which will include changing Cam Seals and Oil Pump main seal. I plan to do as many gasket replacements as I can, because it needs it. Re-adjusting the valves while I'm down there. Alternator and Battery will definitely need to be replaced this year including all accessory belts. The clutch isn't showing any symptoms of failing yet and the transmission shifts very smooth and precise. Modding wise, my full focus will be on the chassis and suspension side of the car, as I have no issue with the current 142hp (many years ago) power plant. My main focus is maintenance right now.
Here's some pics of what she looks like now (sorry for the filters);
