Typical valve tap. Check your valve lash clearance. Some noise is normal.
IMG 4493
IMG 4494
Maybe its just really loud but could valve tap be this loud? Had some of my friends listen to it and they are telling me it kind of sounds like a rod knock, but its weird that the sound comes and goes. If it was a rod knock wouldn't it knock continuously? You could hear towards the end of the IMG 4493 video where the noise just goes away.
IMG 4493
IMG 4494
sounds like valve lash is way out and if its stock the lma are struggling
Ended up pulling the oil pan and finding metal shavings. Getting a oil test done, but most likely my engine is done for.
i didnt want to say it because i wanted to be positive plus i am not there to look at it in person but my original thoughts were rod knock or spun bearing either on the rods or mains
