1 - 2 of 2 Posts
I just bought an 2000 integra and from the vin # its a gsr and it has an obd1 b18b1 from what i read and tried to smog it but it failed because it had code p1457 because theres EVAP leak. Then I saw this hose (pic 1) which I've researched and I'm pretty sure it's the purge solenoid. I was trying to see where it would connect but cant find where it would go on the charcoal canister. I just wanted to be sure that the code is because of it and if there's anything I can do.
Any help is greatly appreciated! Thank you!
I was also wondering if the charcoal canister or throttle body were the wrong one for this swap because the purge line goes into the throttle body not the purge solenoid
This is what my obd1 b18b1 charcoal canister setup looks like.
The hose on your Your tb looks right but Your missing the purge valve on the intake manifold and you can see someone has plugged the hose in your photos.
Your charcoal canister also does have the provision for a purge valve.
106378
106380
106381
1 - 2 of 2 Posts
