I've been having some difficulties locating rear trailing arms for my 98 GS-R. Anybody know of any part links or specialty shops for suspension parts?
Any help would be greatly appreciated.
Did your car get in a wreck or are they rusted out? If yes, you need to replace the entire arm...Used: eBay or local junk yard or New Acura Parts.
105900
If neither wrecked nor rusted out, you probably just need the 3" rear trailing arm bushing (highlighted). You need either a hydraulic press, some rental tools, and a helper OR take the arms off and bring them to a shop with a hydraulic press. Measure the lip top and bottom of BOTH sides of EACH bushing before taking them out. I used a digital caliper for this because the measurement is very small and very precise. Write these numbers down and check them when you (or your mechanic) are done. If the bushing is pressed in too far or too little, it will stretch out of shape something awful when you get an alignment and the bushings will have a VERY SHORT LIFE. Ask me how I know.
There are three varieties of 3" trailing arm bushing currently available...Chinese rendition of OE (e.g. Mevotech, Dorman, Moog, etc.), Chinese rendition of Mugen (e.g. former NAPA Chassis Part, AC Delco Professional), and polyurethane. I have Energy polys on everything but the TAB. They suck, but they do corner harder. The Chinese OE's are cheap, but weak. You can expect them to last 1-3 years before tearing again. The Chinese Mugen clones are physically heavier and you can expect them to last 4-6 years. If you get one with a "lifetime warranty" you'd better scan your receipt from wherever you got them because none of them have logos or date stamps on them and NO ONE will honor the warranty without a receipt.
Mugen clone...notice the meaty insides, rounded edge, and textured bolting bracket?
105901
Chinese junk version of OE...thin, weak, rubber flashing errors, and no texturing on bracket.
105902
Remember, after you're done replacing whatever (whole arm or bushing), go get an alignment.
Edit:
In the event that by some miracle your TAB's are in great shape, the only other thing that can go wrong with the trailing arms are the rear bearings. Mine were surprisingly easy to replace when they started making the hollow scratching sound like they do when the bearings are starting to fail. For others who find this thread in the future...here ya go...
105914
105915
105916
Notes:
1. Removal #12...can also put a lug nut partially on and hit back of disc with rubber mallet.
2. Removal #14...rent a slide hammer to take the hub off.
3. Installation #2...will probably have to turn the brake caliper in and bleed some fluid off to make installing the pads & caliper easier. YouTube it.
4. Installation: all. ...rent a torque wrench(es) (or buy at harbor freight...1/2" & 1/4") to reassemble properly. If you don't have access to a 1/4" T/W, 86 INCH-lbs is hand tight, NOT gorilla tight.
5. Fasteners...
  • Lug nuts - 19mm or 3/4" ...80 ft-lbs
  • Axle [spindle] nut - 32mm ...134 ft-lbs
  • Disc retainer screws - #4 Phillips impact ...86 INCH-lbs
  • Shield bolts - 10mm ...86 INCH-lbs
  • Brake hose bolts - 10mm ...86 INCH-lbs
  • Brake caliper bolts - 14mm ...41 ft-lbs
Thanks so much for the detail info. I cannot do this job myself and have spoken to different garages re repairs and consensus is to change out the whole arm, easier and probably cost the same.
Discussion Starter #5
Actually these are the original bushings I have driven the car only in warm weather months. The bushings are just thoroughly ripped and aged, sway bar links need replacement also.
