I have a 1995 Acura integra ls was driving one day all of a sudden the car just reved up on me at the light and wouldn’t go forward just reving let it cool off drove and did it again doesent want to go forward or reverse but if the car is cold it’s tries o pick the Gears move a little then won’t at all any help plz thanks
If the trans didn't start working again after you added fluid, you probably fried some clutch packs. If you're lucky though, maybe you just lost a solenoid on the trans. If you're really lucky, maybe there's just a loose wire to a solenoid. The two solenoids on top of the transmission (stubby cylinders you can see under the intake duct) are for the torque converter lockup I'm pretty sure. You'd be looking to check the ones near the front bottom of the transmission on the left-hand side.
