1 - 2 of 2 Posts
hey yall, I'm having a problem with my ac in my teggy and I need help asap because these days are getting hotter. So far I've checked all my ac lines and all of them are good, my compressor clutch moves when I press the ac button, checked all the fuses( under the dash, and engine bay), jumped the pressure switch and still nothing just get hot air. and the ac level is still good so I'm super confused. I'm willing to upload pictures too if need. Thanks and be safe!
you likely need a new expansion valve and receiver drier.
maybe schrader valves and o-rings too.
do the receiver last after everything else checks out.
once it's exposed to the air you need to hustle it in there before it absorbs too much moisture.
this thread covers pretty much everything you need to know:
get some good quality 134a like dupont:
most parts stores will rent you the vacuum pump and gauges for free with deposit.
1 - 2 of 2 Posts
