Hello all, Hope all are well.
My 1994 Integra was running real good except when she was cold. I took the idle control valve off and cleaned up. No improvement. I then took the whole throttle body off and cleaned everything.
She started up and ran very rich, then stall.
I thought I ruin the MAP sensor so I replaced.
Still same runs and stalls.
Now she wont start at all, no spark, no fuel pump prime.
I removed pump and tested ok. I don't know much more about what to look for.
Can someone help?
no spark is likely bad coil or icm.
test or just replace as they both die eventually.
wve brand icm just quit on me after barely getting me home 2 days ago.
didn't even last 3 months. 8(
delphi icm has the best reviews on amazon. ngk coil from rockauto
is what i'm running now.
if you haven't done plugs/wires/cap/rotor in the last few years now is a good time.
you want the tec cap and rotor from the stealership. yec is no longer recommended by me. see this:
Thanks Wino, I just got the car from my neighbor last year, I've replaced the Timing belt kit with the water pump, new battery and alternator, new plugs, wires, cap and rotor.
Why would I have lost both spark and no furl pump activity in one day? I don't drive it yet as i am still fixing the many problems it has, I also replaced the exhaust system from Cat back..
bad main relay is a classic no fuel pump issue.
resolder or replace:
