I had my stock mounts taken out (one was broken) and replaced with poly. Can't stand the ride now. Need to figure out what I need to give my shop to throw some fix on the old mounts. Needs just the rubber inserts for this set? What company makes the best OEM mounts?
Why not just purchase oem mounts to give you the feel that you're looking for? As far as the "best" is concerned, you really can't go wrong with factory parts.
I would if they could be had. Acura doesn't have any back stock and they are out of production. Dealer parts couldn't help me.
Thus, I need an OEM-like aftermarket replacement for any thing that is too worn or broken (front mount) on my original set.
Your next option is aftermarket:
Pretty much. I have been all over the internet and seen RockAuto in my search. Just not sure about the brands and the quality. I have read Duralast sucks even if somewhat popular (maybe only because its at AutoZone). Beck Arnley & Anchor were mentioned in the forums but B.A. only show the front mount on their site, no others. Only 3 avail from Anchor (front, rear, L - no passenger/transmission). That said, with the condition of mine maybe I only need the front?
Which ones would you buy? Should the factory mounts all get a replacement rubber piece? Seems the thing to do but I don't work on my car. I just bring parts to my shop as they don't have the time to search out what isn't in their readily available inventory.
