1 - 1 of 1 Posts
1990 Integra. dash lights light up. Motor will not turn over.
I did all the Electrical - fuses - relays - distributor - starter - starter relay- ignition module- fuel pump- battery- key ignition switch- you name it. poked probed I tested it and replaced what may cause no crank.
What the cause was grounding to the transmission, I had 1 to the motor. the ground to transmission died. Installed in a 10 gauge copper to the body next to the battery ground cable. simple fix but finding the problem 3.5 days to find it. I YOUTUBE the crap of symptoms, I did all and very thing that came close to problem. none were the fix. check ground 1st hind sight.
Hope this helps anyone with NO CRANK. This should cover most that have this problem. :werd:
1 - 1 of 1 Posts
