i am going to buy a used 14b off my buddy, for 70 bucks. he said is spulled up fine n his talon. i showed one of my other buddys and he said that since the turbine wheel spins freely its blown. does that mean that it is blown. There is minimum shaft play, and is probably in spec. any info is greatly helpful.
It should spin freely. And shaft play is the major wear indicator.
In and out play is much worse than up and down play (if I am remembering that correctly)
Do you mean the WG spring is set to 10-12 psi?
you just have to get a 6 or 8 psi spring, if you dont have forged internals.. btw is it externally or internally gated?
