Looking to buy 10mm Transmission oil cooling hose
OEM discontinued
All these parts store including RockAuto does not have it.
Any idea where I can buy some?
Need 500mm + 900 mm = 14cm in total length
Diameter needs to be 10mm so that it fits Radiator
Part #
25213-PG6-900
25214-PG6-900
Unsure if the web site is lying - Naples Acura had it for less but when I called they said none in stock. In addition, the price is $105.11
The OEM ID is 10mm.
Would ID 9.5mm works? I can buy ID 9.5mm for $10 - needs to cut - and the extra layer of shield in the link above (part #4) is not available :
https://www.pepboys.com/product/details/9499397/00827?quantity=1
The old hose has not been problematic. Why spend $100 if I can do with $10? I hope the extra layer of shield is removable from the old part.
Any thoughts?
