2001 Integra GS 1.8L
hello I have a 01 Teg Gs that has a high idle issue I have replaced the iac and the tps sensors but my idle stays at 2000 rpm I have adjusted my bleed screw on the throttle body also any help or ideas would be greatly appreciated
If it's an automatic, there is a cold start valve mounted beneath the throttle body. It is not tied in any way to the ECU and has 2 coolant lines attached to it. Yours could be stuck open.
Does your RPM remain at 2k when you unplug the IAC?
And I assume you've verified that you're throttle plate is fully closing.
its a manual and yes my throttle blade is closing completely I will have to check the iac I recently replaced it with a new oem one thanks for responding
