Need help with 94 integra LS Auto - Page 2 - Team Integra Forums - Team Integra
post #15 of 17 (permalink) Old 06-10-2019, 05:37 PM Thread Starter
installed new fuel filter today and you guest it! i am still having the same issue. i also disconnected some of the sensors to see if i can identify if any of them went bad but i didn't notice anything that would lead me to think any of them went bad. disconnecting the TPS caused my idle to go up and down nothing out of the usual. disconnecting the 02 sensor literally did nothing but i did notice something about the MAP sensor. when the Map was disconnected the idle went high which is normal with the MAP off but instead of the car bogging before cutting off the car just cut off from high idle. i dont know what that means but i am trying to figure it out.
once again i am still ordering all of the parts that i stated above but instead of the tps i am going to get coolant temperature sensor because i just remembered i replaced the TPS
thavillain91 is offline
post #16 of 17 (permalink) Old 06-11-2019, 07:40 PM Thread Starter
today i replaced the fuel pump and now everything works fine, no more bogging then shutting off. i had the fuel pump for a while and never installed it because when i turn the key i can hear the fuel pump turn on but i noticed when i replaced the fuel filter there was barely any pressure so today i went ahead and installed a new one and problem solved...... i think. i am going to drive it tomorrow and report back to finish this up. as always its better to identify the problem before throwing parts at your car but i am no mechanic and under my current circumstance i had to do what i had to do.
k3ntegra likes this.
post #17 of 17 (permalink) Old 06-13-2019, 01:58 PM
Originally Posted by thavillain91 View Post
I am hoping someone can help me with a issue i am having with my integra. the car starts up fine but after driving it for a while it starts rough idle until it shuts off. i replaced the distributor and spark plugs and it still does the same thing. if i leave it alone for a while it will start and run for a bit until it warms up then i am in trouble. i am desperate at this point because no car = no money. i do have a video but i do not think this forum allow videos, any help would be appreciated
I had similar problem, and mine was the ignition control module.. replaced that, and the plugs, and it runs great again.
Strandog is offline
