Team Integra Forums - Team Integra - View Single Post - Water spots? on gauge cluster?
post #13 of (permalink) Old 07-24-2015, 10:05 PM
reluktantskeptik
I had the same problem in my 95 SE. Tried all kinds of cleaners and nothing helped as it seemed to be in the first few layers of the plastic. Took out the cluster, removed the plastic face cover, and took a 3M headlight buffer kit to it. 15 minutes later it looked like a new faceplate. Just make sure you remove the rubber grommet from around the trip reset button whole before you start sanding it, and it should be fine.
reluktantskeptik is offline
