Thoughts on 17x8 inch rims. - Team Integra Forums - Team Integra
post #1 of 10 (permalink) Old 09-17-2018, 05:07 AM Thread Starter
Hi all,I have a stock 95 integra and have some 17x8 inch rims in the garage,I'm thinking of 215/35r17 for the tyres...I. am no expert and very new to this so hoping someone can give me some advice from experience.
Thanks in advance.
Josh
Joshxystus is offline
post #2 of 10 (permalink) Old 09-23-2018, 02:20 PM
I'd personally stick to 215/40/R17 to preserve the rims. Give them some extra cushion. The roads are not perfect, as you know.
post #3 of 10 (permalink) Old 09-25-2018, 05:23 AM
What is the offset on the 17x8" rims? This will determine if the 215-40-17 will fit or not.
One more thing do you know you have to roll the fender to fit the 17s.
About time I can now apply for Historic Tags for my GS/VTEC Automatic and no more SMOG
In other news: New edition to the family born on August 21, 2018 @ 3:10am
phatintegra is offline
post #4 of 10 (permalink) Old 09-26-2018, 08:35 AM
deesautohouse's Avatar
17's are pretty huge on these cars. You will most likely rub and you'll feel the road harshness a lot more bc your tires will be so thin. I'd recommend selling and stepping down to 16's or 15's, but if you do go 17 then your tire choice is correct.
Previously: mr2lickit (lost account)
Cars:
2000 Integra GSR - Stolen
1995 Integra RS
deesautohouse is offline
post #5 of 10 (permalink) Old 09-26-2018, 10:56 AM
Silvia's Avatar
215/40/17 should be fine. I’m running 17x9 +20 offset. I’m stretch running 205/40/17. Depending on your offset you will need a camber kit to adjust if slammed and rubbing. You can check my build in my signature and see the setup I’m running. Last page.
Silvia is offline
post #6 of 10 (permalink) Old 09-26-2018, 03:33 PM
Originally Posted by Silvia View Post
215/40/17 should be fine. Iím running 17x9 +20 offset. Iím stretch running 205/40/17. Depending on your offset you will need a camber kit to adjust if slammed and rubbing. You can check my build in my signature and see the setup Iím running. Last page.
Yo your car looks good! I can't believe you don't rub with 17x9 though.
post #7 of 10 (permalink) Old 09-27-2018, 01:06 AM
Silvia's Avatar
Thanks boss. I do rub on my fronts if I have passengers. I rolled the rear fenders. I set the camber to barely clear couple pieces of paper.
Silvia is offline
post #8 of 10 (permalink) Old 11-02-2018, 02:08 PM
That’s not too much. Depending on the style 17” is perfect. These are my type c on my integra. It’s for sale too!
ID:	80048   Click image for larger version
Dcx27 is offline
post #9 of 10 (permalink) Old 11-02-2018, 02:43 PM
SSR Type C?
post #10 of 10 (permalink) Old 11-02-2018, 07:38 PM
Racing hart type C
Dcx27 is offline
