Team Integra Forums - Team Integra - View Single Post - Get engine low enough, to get direct view of timing belt tensioner?
post #13 of (permalink) Old 04-06-2019, 05:37 PM Thread Starter
k3ntegra
Vise grips were no good in my case. I'd like to also advise other from using a drill to remove the bolt; small m7 bits just ended up snapping, and the big ones getting dull. Hopefully angle grinder will do the trick.
In case anyone's interested:
With the exhaust manifold removed, I was able to remove the green and purple bolts (latter slightly loosened to make it pivot) pictured below, from under the vehicle. For the blue bolt, I had to remove air-intake hose. Also had to dismount the radiator(?) hose at the front of the engine, and disconnect fuel filter hose, to prevent them from getting damaged while lowering engine.
Edit:
The passenger side mounts both need to be loosened, in order to bring the engine low enough to get a direct line of sight of the tensioner bolt.
I was able to use a 20v battery powered grinder to take off the head of the bolt in under 5 minutes, then use my hand and un-thread it.
I was able to also use 'cheap' HSS M2(?) left-handed drill bits to remove that AC compress tensioner bolt that has tendency to snap off.
2001 Integra GS Automatic Coupe; B18B1: 240,000 miles.
k3ntegra is offline
