Team Integra Forums - Team Integra - View Single Post - Get engine low enough, to get direct view of timing belt tensioner?
post #10 of (permalink) Old 04-02-2019, 02:42 PM
Absolute_Yeti
Absolute_Yeti's Avatar
Originally Posted by Built_not_bought View Post
Didn't read the whole thread, so forgive me if I repeat the information. You may want to use a Dremel tool and simply make a cut across, right through the center of the bolt head. Then take plyers and squeeze both head halves together. You should then be able to remove the tensioner bolt with your fingers. Goodluck!
I like the sound of that method, I have a few brake carrier bolts that are seized i'll try that on
B18b1
Absolute_Yeti is online now
