Team Integra Forums - Team Integra - View Single Post - Special Idle Surging Issue
post #10 of (permalink) Old 03-01-2019, 06:42 PM
Absolute_Yeti
Absolute_Yeti's Avatar
probably wouldn't hurt if you know the brake booster is already bad/going. you can also do a vacuum leak test by either the cigar test or the soap water test. Cigar test is using smoke to find positive or negative air leaks, soap test typically works on positive air leaks.
B18b1
Absolute_Yeti is offline
